What stall convertor?
Old Aug 30, 2004 | 10:04 PM
ThommyDee's86Z's Avatar
Car: 86 Z28 w/ T Tops
Engine: 305 SB w/ Performer intake 3701
Transmission: 700 R4
Axle/Gears: stock
I bought a used 700R4 today. It is from a 1990 camaro vin#1G1FP23E4LL124860. They also gave me the torque convertor. It has some #'s on it DG5C and 8653087 with 6R stamped all around it. I believe it is a 12 inch.
Any way to find out what the stall would be on this convertor?
Based on my specs what would the best stall speed be?
Old Sep 1, 2004 | 03:29 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Well techinally speaking you would be buying a torque converter with a stall rating of x,xxx rpm, not a stall converter!!! :lala:
Sorry... that is just one of my pet peeves...
With a stock motor, I would say no more than a SLP 2400 stall TC... W/ more mods, bigger cam, etc... you would need more.
I am about to put in a Yank 3500 rpm stall TC in my car... to match up well w/ the setup I have though. I may go bigger depending on how well that works...
The size of the stall RPM will depend on your current setup.
Old Sep 1, 2004 | 05:41 PM
Axle/Gears: stock
Point taken.
Would you say mine is mildly modified. It is all bolt on from the block up.
So 2400 - 2800 would be about right?
Any idea what the one they gave me would be?
Old Sep 1, 2004 | 11:09 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
More than likely its a stocker... so about an 1800 probably.
You could get an S10 converter, same as the Vette pieces, which is a 12" 2200 or 2400 I think...
I would use that or an SLP 2400...
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
