PUT IN A NEW TORQUE CONVERTER AND IT IS NOT FILLING UP WITH FLUID. I PUT IT IN DRIVE AND AND HELD THE BRAKE AND REVED THE MOTOR A BIT AND I CAN HEAR THE TORQUE CONVERTER SPINING WITH OUT FLUID. ANY ONE KNOWS TO WHY THIS IS HAPPENING OR SOME KIND OF EXPLANATION.
Did you fill the converter before you installed it?
pull a cooler line and start her up.is the oil coming out.if it isnt you broke the pump .if it is you may have installed a 30 spline convertor on a 27 spline 700r4 transmission
WELL MY DUMB *** FORGOT TO FILL IT WITH A QWART OF TRANNY FLUID. FOUND THAT OUT AFTER I REASERCHED IT.
