rear end
Transmission: 4L80E/4L80E
1) Counting the bolts on the rear cover will tell you the general type.
2) Remove said bolts & cover, there will be #'s stamped on the pinion and ring gears telling you the ratio. Presence or absence of springs in the carrier will tell you open or posi.
This is the sure-fire method. There is also a 3-character code stamped on the top of the passenger side axle tube that can be decoded to tell you at least what it was at one time.
Car: 87 Z28
its not the stock rear.. its a 10 bolt.. its got 3.73's in it, its an open... i just dont know what year it came from... so im not sure if it has 26 or 28 spline axles...
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
