flex plate to converter
Old Sep 4, 2004 | 06:36 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
i put a bow tie 700 in today and i have a question since i have never touched an automatic. when i put the 3 bolts into the converter it pulled it towards the flywheel about 1/8 to 1/4 inch. is that normal? just wanna be sure before running.
Old Sep 4, 2004 | 06:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, that's what it's supposed to do. If it doesn't, you have a problem.
Old Sep 4, 2004 | 07:07 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
RB is correct. Mine did the same thing and operates perfect. If it was really tight, you would could have some big problems
Old Sep 4, 2004 | 07:20 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thanks. anyone know about what the pressure should be? i should be ready for startup sunday and i wont be able to call bowtie overdrives till tuesday. they dont tell you in the instructions it just tells how to take them and then to call them in to them.
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
Kenwood
Sep 11, 2015 12:50 PM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
