filling torque converter ?
Old Sep 1, 2004 | 01:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
when i re installed my transmission, was i supposed to fill the torque converter? because i emptied it out to make it easier to lift up. and re install. doesnt puting oil into the tranny fill the converter as well?
the problem i am having is the tranny not upshifting at full throttle.
Old Sep 1, 2004 | 02:52 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Yes you shoulkd have added some tranny fluid in the converter prior to installing. Even when I replace my oil filter, I fill it up as well prior to installing it. Tranny fluid will eventually get into the converter but you will have to keep an eye on you fluid level. I put about 2- 2 1/2 tranny fluid in my7 friends converter prior to instaling the tranny. I spinned the converter while filling it up making sure to get the fluid inside.
Old Sep 1, 2004 | 02:55 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
yes eric told me you only put 5 or so quartz in to fill it you need about a hole case of ATF the torque converter takes most of the fluid
Old Sep 2, 2004 | 12:04 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ok then the torque converter will eventually get filled with it already installed?
Old Sep 2, 2004 | 01:02 PM
86z/92rs's Avatar
yes but again keep an eye an eye on the tranny dipstick. Do this in the drive way while shifting in drive.
Old Sep 2, 2004 | 08:04 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Putting the torque converter in dry isn't the best thing in the world for it, but it won't stay dry for long. If you've started the car up and moved in enough to know that it won't hit 4th at WOT then the TC has been full for a good long while. It only takes about 30 seconds to get 90% full, and the little air pockets blow out quickly when you're driving it.
BTW it's normal for a 700-R4 to stay in 3rd at WOT. The stock valving won't aloow 4th at WOT. There are a couple of companies that sell kits to supposedly enable WOT 4th gear upshifts, but I hear mixed reviews on whether or not they work. I have no personal experience with it since all of our vehicles are sticks.
If it's not upshifting AT ALL, as in sticks in 1st at WOT, you need to adjust your TV cable. It's been discussed before.
Old Sep 2, 2004 | 09:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i know it wont shift 3rd - 4th at WOT. but im talking about, having it in drive, and from a stop i floor it, about 4500 rpm instead of shifting into second, it seems to go into neutral until i let go the throttle just for a second then it will shift into 2nd. same thing from 2nd into 3rd.
Old Sep 4, 2004 | 07:40 PM
bobsroc's Avatar
Car: 1987 IROCZ
Adjust the TV cable, directions are in the tech actrical section off this sites main page. Check your fuild level as everyone has said, this should help loads.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
