Speedo Gear Question
Old Sep 7, 2004 | 01:48 AM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
If I have an electric speedometer, do I need the "sleeve" that people talk about buying along with the speedo gears?
From what I read on the SE Thirdgen speedo gear tutorial, it implies that you only need a sleeve if it's a cable driven speedo, which mine is not.
Also, I'm having trouble figuring out what tire size to use for my gear choice calculations. I have the stock 92 Z28 wheels that I would swear are 16's, but I took a tape measure to them and they were 17.5?? What's the deal? Am I only supposed to measure from the interior of the rim or the absolute outer diameter?
Thanks.
Old Sep 7, 2004 | 09:59 AM
jamesbob02's Avatar
Car: 92 Z28
Not even a single view yet? Come on guys, pleeeeease?
Old Sep 7, 2004 | 08:24 PM
25THRSS's Avatar
They are 16's and go with 245/50/16 tires. If you are going with a 3.42 gear go with 15/41 speedo gears. Anybody know the part # for the 15 tooth drive gear and the 41 tooth driven gear for electric speedos. I am also not sure if you need a new VSS or not.
Old Sep 7, 2004 | 08:40 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Hey--you measure from the inside of the tire bead--pretty car. I'm putting a '91 T5 into my '82--the T5 has the electronic speedo drive. Do know what I need to put in there to drive my mechanical speedo? Thanks.
Old Sep 8, 2004 | 12:27 AM
jamesbob02's Avatar
Car: 92 Z28
I'm going to 3.73s. I ONLY need to know whether or not I have to buy a different "sleeve" or if that only applies to cable-driven applications.
Old Sep 8, 2004 | 09:18 PM
25THRSS's Avatar
I would really like to know as well.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
