gears
gears
I have 1991 pontiac formula and i plain to change the ring and pinion from 273 to 342. The shop i found said they used precision gears is that a good name brand ? Or what name brand can you recommend ? And how do recalibrate my speedo ?
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You change you speedo using the following link
http://sethirdgen.org/vss.htm
I don't know much about precision gears only that they make gears.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
