3.08 to 3.73, speedo questions
Old Sep 15, 2004 | 09:42 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Okay so here are my questions, first how many teeth would be on the drive gear of an '83 700r4 from a 3.08 car, and with what driven gear could i make the speedo accurate using this tranny.
Also under what circumstances would i NEED to change the drive gear. Thanx
Old Sep 15, 2004 | 02:56 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
anybody, please
Old Sep 15, 2004 | 03:22 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You will need a 15 tooth drive gear and a 45 tooth driven gear. You will also need the offset housing. (for the bigger gear)
Old Sep 17, 2004 | 04:11 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
but whats the stock drive gear on a 3.08 cars tranny?
Old Sep 17, 2004 | 08:23 PM
vjo90RS8's Avatar
Car: 2002 Z28
use the calculator at www.700r4.com
Old Sep 17, 2004 | 09:24 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
thats just a calculator though, it gives me no definite answer to how many teeth the stock drive gear has.
Old Sep 21, 2004 | 07:14 AM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Drive gear 17 teeth, speedo gear 41-43 teeth. Dependes on your tire size what speed gear you use. Check out Tricksters answer and chart to my question Speedometer drive gears.
Bubbajones_ya
Aug 28, 2015 02:17 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Regal105
Aug 23, 2015 03:45 PM
redmaroz
Aug 16, 2015 11:40 PM
