Can't downshift to 3rd
Old Sep 16, 2004 | 12:20 PM
rnyost's Avatar
Car: 1989 Flame Red GTA 5spd, 89 Bright
Engine: 305tpi and 350tpi
Transmission: Auto and 5spd
Hello again! I have a new problem. My 89 305tpi/5spd is having trouble downshifting into 3rd gear. It will upshift into 3rd with no problems but if I try to go from 4th to 3rd it won't go in unless I'm almost stopped. Any ideas?
Old Sep 16, 2004 | 09:49 PM
kd5boc's Avatar
Car: 92 RS
More than likely you may have garbage in your TV Valve...does it downshift from third to 2nd or 1st?
To clean it, drop your pan. Remove the accumulator housing and valve at passenger front of tranny. Pull pin at end next to cable, and the TV housing should come out. Clean it up and put it back in.
Good luck!
Old Sep 17, 2004 | 05:40 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Huh
Not to be rude, but he said T-5, thats a manual tranny. I have this same problem in my 89 firebird formula, 305 TPI, T-5. Replacing the synchros is about the only solution. I tried changing the tranny fluid, didn't help. Any one have any other ideas please let us know
Old Sep 17, 2004 | 07:36 AM
88firebird's Avatar
Car: 89 GTA (88 Firebird V6 to V8 conversion RIP)
Transmission: 5 spd
Same problem here guys.... my 89 GTA does the same thing... check out this thread for some more details:
https://www.thirdgen.org/techbb2/sho...hreadid=251191
Old Sep 17, 2004 | 07:55 AM
kd5boc's Avatar
Car: 92 RS
Re: Huh
Whoops!
I was looking at his sidebar.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Dragonsys
Sep 25, 2015 03:51 PM
