Tranny questions
Old Sep 16, 2004 | 09:43 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Tranny questions
Tonight while under my car, I push on my dirveshaft toward the front of the car, and the tranny moved up and down, Is this bad? Thanks
Old Sep 17, 2004 | 09:01 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The tranny should "basically" be rock solid against the crossmember. If you're under the car, and try to push the tailshaft (back) of the trans up towards the sky, and it moves, then the trans mount is bad. (Everything hinges on the motor mounts so if the trans mount is bad, the trans will push up easily.) Either $15 at the local store for a new rubber mount that will break in a few years, or $20 at http://www.summitracing.com for the Energy Suspension GM Trans Mount (look under the Chassis section of the online catalog), and that ES mount won't break.
Old Sep 17, 2004 | 11:28 AM
Engine: 2.8 Lt
Transmission: 5 Spd
Yeah it moves up and down. Could this be what is causing the studdering in 2nd gr where it jerks the car back and fourth?Yeah I will get a good one. I do have a five speed if that matters any. How hard is it to change? Thanks tom p
Old Sep 17, 2004 | 01:38 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
its cake to change. Its been a while for me, but you could probably do it in less than an hour.
Old Sep 17, 2004 | 09:02 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
take a floor jack, jack up the tranny just a bit so its being held, undo the tranny crossmember and put new mount in. replace tranny mount let jack down and go nuts
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
