Ticking from trans....
Old Sep 16, 2004 | 11:21 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I just noticed. Once in a while when I start up the IROC-Z, there is a ticking coming from around the TQ converter area. It only lasts for about 30-60 seconds then goes away. Anyone know what this is?
Old Sep 16, 2004 | 11:39 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
My car makes a ticking sound as well at first. I thought it was coming from behind the dash, I don't know if it is as low as where the TC would be, but I'm curious to know what your problem is anyways.
Old Sep 17, 2004 | 06:46 AM
ede's Avatar
ede
i'd look for lose bolts and cracks in flex plate
Old Sep 17, 2004 | 01:03 PM
Administrator
That's what I thought. Any reason why it would go away so fast?
Old Sep 17, 2004 | 01:33 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
if it were loose bolts on the torque converter it wouldnt go away but it couldnt hurt to drop down and snug them up anyway ..
could it be a very small exhaust leak that when it gets heated up the leak gets sealed from expansion?
Old Sep 17, 2004 | 01:36 PM
ljnowell's Avatar
I had a 1978 cutlass that did that. Hmm, thegeneral had a 1978 cutlass that did that too. They were both whit too, wait a minute..........
Old Sep 17, 2004 | 03:31 PM
THEGENERAL's Avatar
hmmm suspicious???????
Old Sep 20, 2004 | 11:39 PM
Administrator
I noticed now that it is also ticking when revving too. If I hold it at 2,000 RPM it is pretty constant. Can a vibration be associated with this in any way? So far it is sounding like flexplate or loose bolts correct?
Old Sep 22, 2004 | 06:59 PM
Pro Built Automatics's Avatar
It could it be an exhaust leak, that when it heats up the leak seals from expansion? If it does not change, then most likely something in the flex plate & torque converter area.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
