Clutch Fork
Old Sep 20, 2004 | 02:10 PM
bigj85z-28's Avatar
Car: 79 z-28
Engine: Built 406 w/ Nitrous Works 250 shot
Transmission: TCI Th-350
Axle/Gears: 8.5" 10bolt 3.73 and Auburn Pro
Clutch Fork
I have an 82 z-28 with a T-10. While putting in the new clutch i noticed that the fingers on the back of the clutch fork, one was broken off. Where can I get another clutch fork for a T-10, or will one off a T-5 work as well? BTW i have a lakewood bellhousing if it matters. Thanks.
-Justin
Old Sep 21, 2004 | 12:12 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The ones for the hydraulic T5's are different, not sure about the 83 manual T5 piece, but you should be able to get the number off yours and cross-reference it. There are usually some available on eBay.
Old Sep 21, 2004 | 12:59 PM
bigj85z-28's Avatar
Car: 79 z-28
well mine has been converted to a hydraulic setup. the car used to be an auto, and had the hydraulics and t-10 swapped in. Would the lakewood bellhousing allow me to use a different fork, as long as it was the correct length? I have found a fork that has the same length, but has a 20 degree or so bend in it.
-Justin
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
mygta87
Sep 14, 2015 10:36 PM
