what is my rear end??
Old Sep 30, 2004 | 02:57 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
i was wonderin if anybody knew what my rear end was and what would be a upgrade for it? i want posi so can anybody help me out?:hail:
Old Sep 30, 2004 | 03:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It was a 7½" 10-bolt.
Yes there are posi upgrades available for it.
There may also be better gear ratios that you can get for it; that would of course depend on what's in it now.
I don't have an extra posi that will fit it, so I can't help you out very much.
Old Sep 30, 2004 | 03:05 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Probably a regular 7.5" ten-bolt (count to see if it has ten bolts holding the cover on). Plenty of mods and upgrades available. Just click one of the sponsors up top.
Old Sep 30, 2004 | 05:52 PM
Night rider327's Avatar
Car: 1988 Camaro
If the car is a 1988 2.8L camaro (same as what mine came out as)
it's a 7.625" 10 bolt, with 30-7/16" long 26 spline axles, 3.42:1 gear
82-84 is 7.5" with 26 spline axles
85-89 is a 7.625" with 26 spline axles
90-92 is a 7.625" with 28 spline axles
There's alot to pick from when it comes to limited slip units. The aftermarket is full of them... Everything for clutch to cone limited slip units, to lockers, spools, and mini spools
Old Sep 30, 2004 | 09:58 PM
wc00ac's Avatar
Car: 92 Camaro
Engine: 305 TBI
i was planning on doing the same and if i put 3.73 gears in will i have to change the carrier as well
Old Sep 30, 2004 | 10:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Depends on what's in it now.
If it's 3.08 or lower, you'll have to hange the carrier (which you would anyway to make it posi); or use a spacer; or use the "special" gears.
If it's 3.23 or higher, regular gears will work on your existing (non-posi) carrier, that you want to get rid of anyway.
Doesn't seem to be much of an issue, really; since you want posi. Get a 3-series posi carrier, and 3-series gears will bolt right up and work.
Old Oct 1, 2004 | 09:10 PM
wc00ac's Avatar
Car: 92 Camaro
Engine: 305 TBI
i have the stock gears and i want the 3.73 gears, so i will have to get the carrier and all. i dont know that much and this will be my first time doing this so i really dont have a clue what to get so the help is much appreciated
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
