t56 swappers
Old Oct 2, 2004 | 08:34 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
t56 swappers
One quick question,,,I have a 91 camaro that I am doing the swap on, do I need the Dakota box?? Thanks Eric
Old Oct 2, 2004 | 10:27 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes, the only way I have heard about to get around this is if you have a 90-92 tpi 305/350 it is rumored you can burn a chip that will work
Old Oct 2, 2004 | 10:41 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Well I do have a 91 that had a 350 tpi but now is a minirammed 383. I have heard that you dont need it for later models but you do for earlier ones. I will be having a new chipped burned once everything is done, thanks for the help, Eric
Old Oct 2, 2004 | 12:58 PM
Engine: ls1, LB9
I can't remember what post is was in but, it bassically tells you what to change as far as the speedo signal part of the chip. I think it takes some trial and error so you may need to burn the chips your self
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
