Torque Converter
Old Oct 8, 2004 | 03:34 PM
STOLN's Avatar
Torque Converter
Does anyone know what resister you would need to trick the electronics on a 700r4 automatic from a 91 Camaro so the torque converter does not throw a check engine light. I am swapping a T56 from a '94 into it and as far as I know the only electronics from the auto are the torque converter. Please let me know if I am wrong.
Old Oct 10, 2004 | 06:13 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The VSS signal count from the T56 is nowhere near close to the signal the stock VSS puts out.
To properly do this swap, you should acquire the Dakota Digital signal conversion box (do a search here on thirdgen for "Dakota" in the transmissions forum)
and you should also check into the chip burning forum, because the car will need some tuning to run optimally with the 6 speed.
good luck with it!
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
