Automatic problem
Car: Pontiac Trans-am GTA, model 1987
Engine: (L98) 350 tpi
Transmission: 4 speed automatic with overdrive
Automatic problem
Hi, I want to know if there is a pattern to tight the automatic bolts in my car. Cause since I pay for changing the oil and the filter it stills droping oil.
Any sugestion IŽll really apreciate them.
Car: `86 SS / `87 SS
You should tighten
1 3 5 7 9 11 13
and then keep going around the perimeter until they are all tightened.
The black pan gasket from GM or AC Delco is better at stopping leaks than the cork gaskets available.
1 3 5 7 9 11 13
