buffer box style VSS with mech cable, how does it work
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i need to find out how buffer box mechanical cable type VSS works,
why is the buffer box way up on back of speedo, and what does it do ? sends something to the engine ECM or ?
why ? and when ? and what kind of signal
instead of making an electric unit at the tranny (like the later style VSS) they put the buffer box in the dash so that its closer to the ECM or ?
looks like 83 was first year for this, judging by what ive seen when disassembling gm trucks, i cant recall seeing one in the dash of a vehicle older than 83, some are black and some are yellow i know, plastic, red and green wires
thanks for any info, links, diagrams etc, i need to learn about this, im a GM guy and more i can learn the better
then i will try and learn about the 93 or so up true VSS system, i think they send like 3000 pulses a mile or something like that ?
thanks
thanks
Car: `86 SS / `87 SS
Re: buffer box style VSS with mech cable, how does it work
Why? Because mass produced VSS speedos, an optical sensor / buffer box are cheaper than multiple speedo cables per chassis and servos on the fenderwell. Also less work to install when the cars are produced.
I don't know if 82-83 f-bodies had the servo on the fenderwell.
The back of the speedo VSS sends a signal to a buffer box, and that signal is split out to the cruise and to the ECM on some cable speedo equipped GM cars. They also made cars with a cruise servo for cruise and the VSS speedo for the ECM signal.
The # of pulses per mile increases with the higher numerically differential gears. This differs from the earlier VSS's becuase those were still geared to make the pulses per mile signal correct by use of mechanical speedometer gears.
From one GM guy to another...
-Matthew
Car: 4
Engine: 6
Transmission: 5
The little yellow box is an optical deal. It literally "looks" at the piece of the speedo that's connected to the cable.
The piece of the speedo that spins is a U-shaped magnet about an inch long, with the legs of the "U" about ¼" tall. The piece that the pointer attaches to is a little metal cylinder about the same height and slightly smaller in diameter, that sits in between the "U". As the magnet spins, it tries to carry the cylinder along with it; the faster it goes, the more force it applies to the cylinder. That's what makes the pointer move.
The magnet is shiny, and the cyl is painted black. Since in all cable speedos the cable rotates exactly 1000 truns per mile (remember, the odometer is nothing more or less than a turns counter) the magnet is rotated at that speed. The little yellow box with its LED and phototransistor sees the magnet's 2 arms go by, once per revolution; since there are 2 arms, that's 2 pulses per rev, or 2000 per mile.
It provides the signal to the ECM so that it knows when to lock up the torque converter, and for various emissions-related decisions even in a stick-shift car.
The factory cruise control in those cars is entirely mechanical and is separate from the VSS and the ECM. It works on a similar principle, with a spinning magnet and an electrical "latch" that captures a spring tightness, and a vacuum valve that opens or closes based on whether the spinning magnet moves the stationary disc with enough force to overcome the spring.
9192camaro
16
Feb 3, 2019 12:21 AM
