Whining noise....rearend, gears?
Car: 1990 Iroc-z convertible
Engine: 305 TPI LB9
Transmission: 700 R4
While im driving the car makes a whining noise. The best way to describe it is that it sounds like a very muffled air raid siren. Also the car shifts very hard into 2nd, sometimes chirping the tires. I knew when I bought the car that I would need to fix up the trans and/or the rear. I was wondering if anyone had any ideas. To my knowledge the car had 3.73's and a shift kit installed some years ago. Could those be bad?
Could be those gears...but it could be your converter or pump going up too...I blew mine up the other day and it made a really loud whining sound afterwards..probaly the pump for mine but not sure...
Check your tranny fluid..if it is grayish then you have clutch wear going on which your living on borrowed time.
Is the converter stock..they tend to go up..
get it looked at asap at a tranny shop they have special tools that they can listen to the tranny to see if its making noise ect..
better to be safe than sorry...if that converter is going up..it will put metal into the tranny and take everything with it...I had a whining sound several years ago..found out it was the converter..not before it took the whole tranny with it..
Does it make the sound in reverse/or when you first put in in drive and not really moving fast?
Gears don't start making to much noise untill you really get going...a converter /pump make noise even in reverse/or idling in drive...
Well that could be your gears then...if its converter/pump..it usually starts up right as you put it in drive...
You said the tranny shifts hard into second so the actuall tranny itself sounds good...if the pump is bad your shifts are not as clean do to the pump failing to move the fluid...
So I'd lean towards the gears ..which is a much cheaper fix.
Engine: 305 TPI LB9
I live 1/2 way between San Francisco and Sac in Antioch.
UPDATE: I was trying to figure out when exactly the noise starts happening, this is what I noticed. It doesnt start until about 30mph. It only makes noise when I accelerate, I guess because of the load. If I am going 65 and coast, the noise stops. Any ideas on what this can rule out?
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
I too am experiencing this whine noise and it sounds like it's coming from the back end somewhere. When I am driving along going say 45 mph or so, if i get completely off the throttle, I hear no noise. If i give a SMALL amount of throttle, it occurs again, but if i give it medium to 100% throttle, I hear nothing.
Car: 92 camaro
I had the same problem. I found out though that I had a bad rear pinion seal that needed to be replaced. At first I took my rear end apart to check for a bad differential , bearings and pinion gears. Come to find out I had low gear oil. So I filled it up and it went away for a while and then came back. That is when I noticed that it was leaking through the pinon seal.
Transmission: TH200C....700R4
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
If your gears are aftermarket then it could be one of two problems you could just be hearing a little bit of the whinning aftermarket gaears are know to make or the rear is not set up correctly.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It definately sounds like rear end. The gears are worn on the accel side thats why it doesnt make the noise when slowing down but going light on the throttle again meshes the worn sides of the gears in turn making the noise again.
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
