Gear Drives
Old Oct 19, 2004 | 12:06 PM
Iroc5789's Avatar
Gear Drives
Has anyone installed a gear drive on their 3rd gen, computer controlled, roller cam engine? It has always been that you could not use a gear drive on a computer controlled engine, because it would interfere with the knock sensor. Now company's are making gear drives for roller engines, and if it a roller, chances are it has a computer, and knock sensor. Just wondered if anyone has tackled this before?
Old Oct 27, 2004 | 09:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I ran one on my 'bird for awhile. I think Pete Jackson was the only one for awile (when I bought it a good while back) and though it dcaused no problems, it sounded like total ***. Not your traditional wannabe SC whine like elder SBC block geardrives but like, something was loose and ready to fall apart at any given moment type noise.
In all honesty... a geardrive in practical daily purposes is.. just annoying to listen to (as a bud had a 'sneaky pete' on his 71 camaro). Only cool to hear passing by or if the noise is from the real deal.
You'd be just as well off, or better, using a cloyes double roller and calling it a day and a little saved coinage as well.
JMO though... take it as you wish...
Old Oct 28, 2004 | 11:27 AM
Parrydise7's Avatar
I understand there are two different gear drives available: the quiet and the loud, so take your pick. Depends on how the gears are cut IIRC.
With that said, I also understand that the gear drive transmits more vibration to the valve train.
Old Oct 31, 2004 | 12:57 AM
Doug Gulley's Avatar
Car: A Black One
Engine: 383 Chevy
Transmission: Retro T56... :>)
I've got a Pete Jackson "noisy" geardrive on my 383 LTR and had no problems at all. I asked this same question to some members on here and was told they ran them too. They too have no problems.
I also had a PJ geardrive on a 69 Camaro (carbed) bought before their was a noisy or quiet version. It was in the car, which was a daily driver, for well over 15 years and is still in the car to this very day. Never had a bit of valvetrain problems!
Too many people listen to myths without trying anything.
Old Oct 31, 2004 | 01:14 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Interesting--I've wanted to run a PJ gear drive for years but I've chickened out because of the vibration to the valve train comments in magazines. No reason to run one, either, except for the sound--I might try one in my street rod under a Summit polished aluminum cover and Weiand aluminum pump when I feel rich some day. Meanwhile, the Camaro sees a lot of street use during the week--think I'll stick with a chain.
Old Oct 31, 2004 | 01:18 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I have over 55k with a pete jackson "noisy" in my Z (no computer) since 86 never had any problems!
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
