70s f-body 12 bolt in a 3rd gen
Old Oct 19, 2004 | 12:35 PM
slow84ta's Avatar
Car: 84 15th Anniversary Trans Am
Engine: built 406
Axle/Gears: 3.73 10bolt
I've heard of early 70s stock 12 bolts fitting in 3rd gens with little modifacatoin and holding up for years. in fact there is a local guy that I know of around here with a 82 big black camaro runing 10s which had stock 12 bolt for 6 years till it broke, pretty impressive....
anybody have any input about this?
Old Oct 19, 2004 | 01:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't think of any way you'd get one to fit with only "little modification".
Old Oct 19, 2004 | 01:25 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
The 2nd Gen cars had leaf springs if I recall right, and no torque arm, that would fall under major modification if you ask me. You can geet a custom built 12 bolt for these cars, but they arn't cheap. The guy either bought it with that custom rear in there, or lied to you.
Old Oct 19, 2004 | 01:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The only way you are gonna find an F-body 12 bolt rear is if you find a '70 Z28, SS 396, or Trans Am.
1970 was the only year they got a 12 bolt rear end. 1971-81 was all 10 bolt rears. They are better then '82-92 10 bolt rears though, because IIRC, they are quite a bit bigger.
Old Oct 20, 2004 | 09:56 AM
goofnrox's Avatar
8.5" to be exact.
12 bolts are 8.875 IIRC.
A 8.5" 10 bolt is plenty strong, but you still have the torque arm, spring mounting issues.
Old Oct 20, 2004 | 07:50 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 70s f-body 12 bolt in a 3rd gen
A 68-72 A-body differential is the same width as a 70-81 F-body differential. Weld spring perches & shock mounts on and you're good to go if you have a second gen.
Too much fabrication required to put one in an 82-92 F-body.
neekolzun
Aug 24, 2015 04:59 PM
89lsc
Aug 14, 2015 04:58 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
