I want disc brakes and posi!
Old Oct 29, 2004 | 10:43 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Just found a rear out of a 4th gen Trans Am with rear disc brakes and posi that i'd like to put in my Camaro that has neither.I've read a couple of posts on the subject,and it seems pretty much a bolt on,but i've got a couple questions before i go further.Will my 15x7 aluminum z-28 wheels fit the 4th gen rear?I remember reading somewhere that you need spacers or adapters to fit 4th gen wheels on a third gen.I'd really like to keep my rims.Secondly,Can you just hook the old lines to the new rear without changing the master-cylinder or proportioning valve?I'm hoping this works out ,this would be an awesome upgrade for 500$ canadian.Thanks for your time.
Old Oct 29, 2004 | 04:06 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
You won't need spacers. Spacers are for fourth gen wheels on a third gen axle. You current wheels will stick out approx 2 inches on each side. You also mean a 93-97 rear correct? I don't know if LS1 rear brakes will clear 15", I don't think so though.
Old Oct 31, 2004 | 06:34 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I think you'll need a new master cylinder if you're switching from a drum to disc rear.
dbrochard
Oct 3, 2015 12:43 PM
toyotekk
Sep 7, 2015 06:36 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
