rear axle swap question
Old Nov 3, 2004 | 06:09 PM
1bad88TAWS6's Avatar
I currently have a 6hp 2.73std rear axle. i'm thinking about upgrading to an 8xx3.70posi rear axle out of an 86. i was wondering, to make the speedo work correctly, would i need to swap the vehicle speed sensor located on the transmission housing (automatic). i was wondering if this would correct the spedometer? any input is appreciated.
Old Nov 3, 2004 | 06:14 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
yup,
some poeplw will say watch out but as long as the donor car is a bird your good, if its a camaro, the speed sensor is strill gear driven and wont work for shizzle.
Old Nov 3, 2004 | 06:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
IIRC, the 86 firebird still had the mechanical speedometer. If so, you'll need the VSS from your transmission, and you'll need to get the correct gears.
Old Nov 3, 2004 | 07:01 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nope. my 86 trans am has the electroic speedo, soooo. ummm yeah.
Old Nov 3, 2004 | 07:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
So he'll only need the gears then.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
draco
Oct 4, 2015 09:25 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
