700R4 Swap from Caprice to GTA
Old Nov 9, 2004 | 05:21 PM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
Transmission: TH350 / 700R4 / 4L60E
Axle/Gears: custom GM 8-1/2" 456 posie
I am planning on using a 700R4 from a /87 Caprice Classic for my GTA. I assume it will fit, and the tranny mount is the same.
Would anyone know if this swap will work? I believe that I will have to change the rear tail piece so I will have holes for the torch arm, but I am not sure if it is the same shaft length or not. Can someone please tell me if this will work or not.
Old Nov 9, 2004 | 09:06 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
as long it's a 700-r4 then they are the same. some caprices came with a 200-4r. the units are physically them same. only things that would need to be changed would be.....
the tailshaft housing
speedometer gear
trans mount
take those items off your current trans and put them on the "new" one.
Old Nov 10, 2004 | 01:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
One other thing, you will need the shifter bracket for your old trans. Some coulmb shift cars like the caprice have a different bracket but you should be albe to notice if its different.
Old Nov 11, 2004 | 07:49 AM
Oshdog's Avatar
Car: All GM
Engine: All Chevy
thanks
Ok, thanks the information
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
