what size is ur 10 bolts?
Old Nov 12, 2004 | 04:59 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
whats the size on out 10 bolts ina 92 rs i ahve a posi unit out of an s10 thats never been used will it fit in mine?
Old Nov 12, 2004 | 06:01 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
the carriers are the same i used to have a s10 posi in mine..make sure you have axles with the same amount of splines as the posi
Old Nov 30, 2004 | 09:20 PM
Car: 87 Formula
Engine: 350 tpi
bringing this back from the dead axels in my 89 would be 26 spline correct i ahve to dig out the posi unit and check ots goin in my 89 now as a temporary posi fix untill funds improve
Old Dec 2, 2004 | 09:05 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
In '89 you probably have 28 spline axels. This is right in the changeover though, so verify the spline count.
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
