Hey, Pete's 84 Z28 Electronic Dash Swap Help!! Again
Pete,
Need your help again.
Here's what I've done so far:
1. Got the electronic dash and Buffer removed from my 86 and have wired and transferred it to my 82 bird. I followed your directions to the letter, and installed it last night, but nothing worked. I go some movement on the temp gauge, and check engine light, other than that nothing else worked, not even the dash lights. I then realized the I omitted to read the part about, if I'm installing in a 82 - 85 bird I'll have to do some wiring changes on the back of the 86 cluster in order to make it work correctly.
Can you tell me which wire need to go where in order to make this (86) cluster work in my 82? I've done everything else correctly, but am at a loss on how to change the wiring around.
Thanks a lot for your help.,
Jeff Morgan
Report
Jeff Morgan
Report
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
