Detent Cable aka TV Cable Install
Old Nov 17, 2004 | 08:38 AM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I just had the clip on the detent cable that attaches to the throttle body break. I ordered a new detent cable however, do I have to drop the tranny pan to install it? From what I have seen it looks like a simple job and not something that requires removing the tranny pan.
Old Nov 17, 2004 | 09:18 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
It can be put in without pulling the pan. Thats how I have always done it.:rockon:
Old Nov 18, 2004 | 01:04 AM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
Take your time removing the old cable out of the transmission. If I remember correctly, theres just like a little hook sorta in the trans, and a hole in the end of the cable the hook goes through. You just kinda pull the hook up out of the trans a lil bit, and attach the cable, then lower the cable and plastic bracket down in place, and then put the screw back in. Its really not that hard, but on the ground everything is a pain in the ***.
Old Nov 18, 2004 | 01:23 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Your job will be much easier if you drop the cross member. It'll give you more room to work with your hands while its on the ground.
Do yourself a favor though. Buy a new transmission mount if you drop the crossmember. you'll be one bolt away from replacing it. If its the stock mount then its probably old, and torn up. You can replace it with an Energy Suspension mount if you don't mind a little extra interior noise.
The hardest part about his job is keeping the tranny side of the cable hooked up. It likes to slip off the hook unless you can keep some tension on the cable. A 2nd person is really helpful here.
Old Nov 19, 2004 | 05:43 AM
JoshDT91's Avatar
Engine: 2.8L V6
Thanks for all the help. I did it last night and I didn't think I would be able to finish it. At one point I had the cable hooked up and attached to that little hook but I forgot to put the grommet on there. Fortunately I did not have to drop the transsmission at all I was able to work with the tiny amount of room there was.
I cannot imagine what a pain it would be to drop the tranny though. Lucky me a while back the tranny mount broke and a shop did it for me for I think under $40, that includes parts and labor.
Old Nov 19, 2004 | 10:55 AM
Its 5 bolts to unbolt the crossmember. You don't remove the transmission. It takes me all of 5 minutes to unbolt the crossmember and drop the trans for better access.
Not very hard at all. Dropping the cross member would have given you another 3 or 4" of room to work.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
