trans line FITTING size?
Old Nov 17, 2004 | 04:50 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
put this out here before, and someone responded with the line size for the tranny cooler lines, but i need to know what size the FITTINGS are, like a -6 or something? the fitting that screws into the cooler and tranny itself... thanks.
KAM
Old Nov 18, 2004 | 01:09 AM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
Are we talking about running braided stainless steel lines With AN fittings? if so they are sized like you said, 6 AN is a 3/8 hard line.... take the an size and divide by 16 you and you have your size. 8 AN is 1/2 pipe. 6 AN line and fittings will work fine for your tranny cooler, although im not sure if the trans lines are 3/8 or a little smaller. Are you going to run hard line to the cooler? And now heres what comes out of the fortune cookie : Need more info for better answer
Old Nov 19, 2004 | 06:15 AM
Car: '91 Z28
Axle/Gears: 323's
well, i was going to replace the rubber trans lines with the same or better, but upon further review, looks like i'll be going back to hard lines. i had put the rubber ones on a while back cuz i got tired of messing with the others, but... so i needed to get the fittings for the ends of the lines, hence the question.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
3rdgenparts
Aug 5, 2015 11:57 PM
