Can anyone tell me which posi this is?
Just curious if anyone knows what make this posi is, whether its a clutch or cone type diff, and whether or not its rebuildable. I'm hoping to pick it up used if its a decent piece, its out of a 3rd gen 26 spline disc rearend. I assume this isn't a gov-lock diff right? Thanks for any information.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Posi
It's a clutch type, I'm not sure if you can get parts for it tho.
Excellent thanks I won't bother with it then if I can't rebuild it, one more quick question, did GM use Eaton clutch type posi's in 7.5" rear ends during the 80's? I'm looking at bidding on a 26 spline factory eaton posi on ebay and I just want to make sure its legit, its got springs and plates in it so I assume its not a gov-loc. If gm did use Eatons are they rebuildable? I know eaton sells clutch kits on their site but will they fit the 80's era eaton factory posi's? Thanks.
Not sure if this'll work but I'll try and link a pic
KO1
16
Oct 15, 2015 05:00 PM
