xmission cooler lines
Old Nov 18, 2004 | 11:22 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
Apparently, the stock tranny cooler lines have clearance problems with the Edlebrock TES y-pipe. one tranny cooler line rubbed against the y-piper while the other against the starter. so now i have 2 leaking tranny cooler lines. am i going to have to replace both of these lines with stock ones or some kind of custom bended lines to clear the exhaust and starter?? I'm using some high pressure hose, but it's not stopping the leak, and hose probably isn't the best thing to use with all of that heat from the exhaust. HELP!!!! thanks
Old Nov 19, 2004 | 05:43 AM
ede's Avatar
ede
use either steel or braided lines, either will work fine
Old Nov 22, 2004 | 04:08 PM
Car: 1984 Z-28
Engine: L69
Any recommendations for places to look? I'd just assume go through NAPA for stock replacement lines, but what about the braided (flexible) lines? The braided lines sound like it'll be an expensive project, but the benefit of being able to route it around the exhaust almost sounds worth it.
Old Mar 28, 2005 | 03:20 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I'm installing a cooler in my car and will need to make some custom lines.
Is there a reason you guys use steel or braided lines? The max pressure is maybe only 200psi, not 3000psi like the brakes. I'm sure GM uses solid just for durability.
I wonder if there is some cheaper plastic line that would work, like maybe something you could find at Menards?
Bubbajones_ya
Jul 6, 2024 08:32 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
TBRays98
Sep 6, 2015 05:05 PM
apie2546
Sep 5, 2015 07:40 PM
