T5 - removing inspection cover
Car: 88 GTA
Engine: 305 LB9
Can I remove this without pulling the tranny again? I am assuming it requires removing the bolts and the starter (being it hooks around the starter). I just replaced my clutch fork and when I put it all back together, I get a tinny rattle above 2500 RPM. It sounds like the cover , and I figure I'll start there being I only went as far as the bellhousing and there was no noise before.
I don't have a shop manual for an 88 and SEARCH was no help.
BTW, I changed the ATF in the T5 and she is smooth shifting.
Kevin
Kevin
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
There are just 4 10mm-headed bolts holding it on; no need to remove the starter.
Car: 88 GTA
Engine: 305 LB9
...but there's a round cutout that the starter pokes through. If I only remove the four bolts, it will still be attached and pivot on the starter, correct?
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
84, buy, camaro, cover, firebird, gm, inspect, inspection, plate, removal, remove, removing, t5, transmission, transmisson
