What would oit take to make a t-5 handle 450 hp?
Old Nov 27, 2004 | 09:12 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
I seriously want to make my car a manual but I won't be able to buy a t56.
Since it would be easier and cheaper for me to get a t-5 is there a way I can make that handle gobs more tq and hp?
Old Nov 27, 2004 | 10:02 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Not really much you can do, since the case itself is the biggest problem. A four speed would be a good way to go though. I'm going to be installing a T-10 four speed in my Z28 in the spring. Lighter and stronger than any T5, but no OD gear like the T5 and T56.
Old Nov 28, 2004 | 04:13 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Re: What would oit take to make a t-5 handle 450 hp?
Originally posted by CamZ28
What would it take to make a t-5 handle 450 hp?
An Act of ***.
Old Nov 28, 2004 | 04:22 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You could change the t-5 guts out for G-Force parts, they say it's good for about 600 HP. Here is the website http://www.gforcetransmissions.com/tran_gt-5.asp
Old Nov 28, 2004 | 07:27 PM
TexasLT1's Avatar
Car: '92 RS
Why don't you want a T-56? Nothing you do to beef up a T-5 is going to be cheap.
*edit* nevermind, I misread your post. I'd wait until you can get a T-56, because the G-Force kit cost almost as much as what you can get one for, and you'll be better off with the 6 speed.
Old Nov 29, 2004 | 12:20 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Contact TKOPerformance at BigRedK5Blazer@aol.com; they'll rebuild a WC T5 using forged parts to handle 400/450 ft. lbs./hp for about $700 plus shipping.
Old Nov 29, 2004 | 01:32 AM
CrazyHawaiian's Avatar
Car: too many ...
I dunno, I would rather build a T5 instead of doing the T56 swap. From a price standpoint, you also gotta consider the rest of the parts needed for the T56 conversion. I guess its worth it if you want a 6 speed and thats that. But if you're happy with a 5 speed and you just need it stronger then building the T5 and retaining all the rest of the stock equipment is probably the cheaper way to go. I know thats the way I'm going with 2 of my cars (both of which were/are auto)
Old Nov 29, 2004 | 02:04 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
id say a big as s wad of bills or start wishing upon the stars
Old Nov 29, 2004 | 02:18 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
Do they do non w/c t-5s? and where are the casting numbers to find out if mines w/c or not?
Old Nov 29, 2004 | 08:57 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Well, I wouldn't think they'd do a non-WC T5, but give them a try. They know their stuff.
As far as ID'ing trannies, RB83L69 has posted fotos of the differences in T5's--very obvious when you see the front covers. Do a search for those fotos if you can.
As far as expense and hassle for the T56 conversion, well, if you're into it, the T56 is the ultimate indestructible tranny; but it weighs about 50 lbs more than a T5, requires a bunch of proprietary clutch stuff and fabrication, shifts slower than a T5, and Chevy High Performance magazine says that if you're running a carb and a mild cam you should have at least 4.10 in the rear so you can put it in sixth--basically a smog tranny. I have one in a street rod but it's sort of a conversation piece--might go back to the Muncie M21. My Camaro will remain a T5--but it's a cruiser, not a drag racer.
If you have EFI a T56 would probably give you great mileage.
Old Nov 29, 2004 | 10:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
T56 is nice but who needs 2 over drives???
If they made it a 5 speed with 1 OD that would be nice.
Old Nov 29, 2004 | 10:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
A nice close ratio 5 speed with an OD for mileage would be great.
Even better if it was linear like a motorcycle. Ditch the shift pattern for more speed.
Old Nov 30, 2004 | 09:23 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Hmmm...interesting...
Old Dec 5, 2004 | 08:41 AM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
The G-FORCE kit kicks butt I have 20k miles on mine and I beat on it like there is no tomorrow and with the rebuild video from www.hanlonmotorsports.com it was fairly easy to do and when I did run into a problem the people at hanlon were amazingly helpful, Service sells in my book. and with a T-5 it looks stock no new clutch crap no new x member, driveshaft, torque arm and you don't have to figure out all that vehicle speed sensor crap, anyway yeah
just my 2 cents
Ryan
Old Dec 5, 2004 | 09:46 AM
TexasLT1's Avatar
Car: '92 RS
Someone who wants to put 4.10 or higher gears in the rear and still get good gas mileage on the highway.
Old Dec 5, 2004 | 09:47 AM
TexasLT1's Avatar
Car: '92 RS
Its called sequential. And they cost about $5000.
Old Dec 5, 2004 | 10:35 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
a gforce T5 is stronger then a stock T56. call Gforce, ull be surprised at the cars they run them in, they are FAST.
Old Dec 5, 2004 | 09:40 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Outstanding--wierd little red car in the background, though--Pinto?
Old Dec 5, 2004 | 10:28 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
it is sworn enemy, we must kung fu fight
anyways, well find out if it my t5 can handle the 383. gforce kit w/stabilizer, and bronze shift forks from 5speeds.com
Old Dec 5, 2004 | 10:35 PM
nsimmons's Avatar
richmond 6 speed
Old Dec 5, 2004 | 11:16 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
it a good friends 88GT, extremely nice car. looks stock doesnt it? i feel bad for the people that fall for its 14 sec appearance.
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
LT1Formula
Nov 16, 2015 01:13 PM
Cacike
Aug 27, 2015 05:10 PM
sreZ28
Aug 14, 2015 07:48 PM
