Vibration around 2500rpm???
I just bought a b4c car and it has a strange vibration around 2500 rpm in each gear. I have pretty much eliminated the driveshaft because when you push in the clutch and let the car idle down at speed the vibration stops. You can feel the vibration through the shifter. The car has 136000mi on it. Could this be a tranny or motor mount?
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
If the car will vibrate in neutral not moving, try removing the belt/belts to see if vibration is from an accessory. If no change I suspect that maybe a problem with the clutch, with that mileage the trans input shaft & or pilot bearing can be worn out & it makes the clutch assm run out-of-round and subsequently out of balance, a torsion spring in the clutch disc can be out of place also. It is a big job to change the clutch, so get a second opinion.
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
Check bellhousing bolts, and if its an automatic check torque converter bolts. I had a vibration in mine right @ 2500 and my bellhousing and torque converter bolts were loose because I hadnt rechecked them after the motor swap...Tightened bolts it all went away.
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Ditto on the bell housing and TC. Just retightend mine, added some thread-lock and all is well.
Just a few other minor problems.
Jim.
Jim.
roysatikas
Sep 22, 2015 08:15 PM
