converter recomendations
Old Dec 1, 2004 | 07:30 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
Hi there can anyone here give me some ideas on what kinda converter i need for my 700r4 trans.The motor is a 383 and will be in the 450hp area,now ive contacted tci for a recomendation and they say there breakaway converter is what i should run but when i checked the cost it was 500us.Thats just a LITTLE over my budget.I could see 200 but not 500.So can you guys tell me what your running and if you like it.Im running 3.73 gears.Thanx
Old Dec 1, 2004 | 08:09 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You have to look at the companies that make the converters too. Some of the high dollar products come from better companies... They will work with your combo and make sure you get the converter you're looking for than just picking one off the shelf. Also companies like Precesion Industries use higher grade parts that's why they cost more.
When I bought my ACT converter from pro-built (no longer sell it) Dana took my cam, CI, gears, intake, and other things into consideration before selecting a converter speed.
Also another thing most people seem to over look is the diameter size of the converters. Stock is a 12" converter, the smaller diameter you get a slight bump in the 60 foot time (from the multiplier) and also you get less strain put on the drivetrain.
As for me I'm running a 9.5" ACT 2400 right now. It ran right around 500 bucks, but due to problems in the past with the company they are over looked now. Mine has been problem free though.
Old Dec 1, 2004 | 09:51 PM
Car: 1983 Z28
Engine: 383
9.5" converter thats sweet.Has anyone dealt with roadrunner converters,they sell converters on ebay and look resonably priced?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
tell me what ya think?
Old Dec 1, 2004 | 11:05 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Convertors are the last thing people want to spend money on, but also fail to realize it's just as important, no more important, than that $400 set of headers, $300 set of roller rockers, $200 intake, etc...really good convertors are expensive and you will get what you pay for. I realize the budget thing and options have to be weighed out, but cheap is often not the best solution. $400 for a name brand convertor is not unreasonable by any means.
Most of the cheaper brands I've seen run have more slippage and that's one thing you dont need since that turns into heat build up and later turns into another tranny build up.
Old Dec 1, 2004 | 11:29 PM
Car: 1983 Z28
Engine: 383
ya i know your right.guess ill just have to buck up .Good thing is i have till spring to gather more funds .
Jegs has it on for 389 thanx for both your reply's guys
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
