Speedometer moves when engine is revved and other problems.
Old Dec 3, 2004 | 07:25 PM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
I just had a motor swap on my 87 GTA and have ran across a couple of problems.
1. When I rev the motor the Speedometer acts like a Tach. What could be the problem?
2. How do I find a short or whatever is draining my battery? I know somethings pulling current becaues when I disconnect the + lead on the bat I get a pretty big spark. I had an alarm installed and I tried to disconnect it. How can I bypass it to start the car? I think I might have pulled a wrong wire loose somewhere because I am having trouble starting it.
Any suggestions or advice will be appricated.
Old Dec 8, 2004 | 12:32 AM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Wiring reversed?
Happened to my brother a few years ago. Somehow the positive was acting as a ground vs the negative leads.
Jim.
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
