9-bolt vs. 10-bolt
Old Dec 6, 2004 | 05:48 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
9-bolt vs. 10-bolt
Okay, I'm still a newbie, so what's the deal with the Borg-Warner 9-bolt? I have one, and what's the big differences between the two? Do I still need a c-clip eliminator kit? Are the gear ratios different? Which is stronger? I went to 9bolt.com, it had some good information but I still got questions.
Old Dec 6, 2004 | 09:06 PM
TexasLT1's Avatar
Car: '92 RS
9-bolt is much stronger, but parts cost a lot more for it. also, I've heard the posi is more prone to wear and needs to be serviced and slightly modified to be trouble free.
Old Dec 6, 2004 | 11:58 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
10 bolts have a 7.5 or 7.625" ring gear, the 9 bolts have a larger 7.75" ring gear. 9 bolts have 4 spider gears in the carrier and 10 bolts have 2;
9 bolts don't have C clips in them so no, you don't. The 9 bolt axles are retained by the 4 bolts on the axle flange;
Yes. Here's some examples:
10 bolt ratios: 2.73, 3.23, 3.42, 9 bolt ratios: 2.77, 3.08, 3.27, 3.45;
Which is stronger?
9 bolt due to the larger ring gear and 4 spider gears.
Ed
Old Dec 7, 2004 | 10:47 AM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Ah, cool. No c-clips = happy thirdgenner.
Old Dec 12, 2004 | 03:22 PM
supermouse68's Avatar
Car: 1988 firebird
Engine: 462 bbc
when you say 9 bolt are you talking about a 9in ford?
Old Dec 12, 2004 | 05:50 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
uh no hes talking about the BW 9 bolt that came in some 3rd gens.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
3.8TransAM
Sep 17, 2015 02:16 PM
6speedIROC
Sep 13, 2015 01:29 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Fastcamaro87
Oct 19, 2001 02:26 AM
