rear end gears?
Old Dec 8, 2004 | 04:03 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
rear end gears?
okay i'm just wondering whether you can figure out your rear end gear ratio by speed and transmission gear ratio. On the highway i'm going 70 and its spinning about 2500 rpm. i have a th400 trans but third gear is 1:1. does anyone do a calculation and tell me what gears i have or give me an equation to figure it out myself any help would be appriciated. oh by the way stock tires and rims.
Old Dec 8, 2004 | 05:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't bother. Your tach is not accurate enough.
Take off the cover and look, if it really matters to you. All else is monkey-spank and speculation. Besides, if you really care about this car, you need to change the fluid anyway; while you're catching up on the long-overdue maintenance, make a point of looking at the gears.
Same for the next question you're probably about to ask: how can you tell if you have posi.
Old Dec 8, 2004 | 07:08 PM
phoenix305's Avatar
umm no i have an autometer aftermarket tach but thanks for the input any ways
Old Dec 8, 2004 | 09:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
https://www.thirdgen.org/newdesign/t...ulations.shtml
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
