trans slipping in od
Car: 85 Trans Am,79 Trans Am,02 Trans Am
Engine: 5.7 V-8 346 LS1
Transmission: Automatic
I dont know. My transmission was slipping in overdrive. All it needed was to get topped off in tranny oil. Sorry I couldnt answer your question.
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I wouldn't think so. The cruise control would just adjust speed trying to maintain the preset speed. If the trans was slipping it would apply throttle until it forced a 4-3 downshift and brought the speed up to the set level.
If OD is slipping start thinking about a rebuild. The 3/4 clutches are the first to fail. The other sets will follow. It's only a matter of time.
Thanks guys for your replies.I found out what the promble was.I had a inition mod.and coil to both go out at the same time.Fixed those and my cruise is working fine and no more slight jerking or rpm's moving up and down.
Car: 1990 Pontiac Firebird
Engine: v6 3.1L
Axle/Gears: ???
Re: trans slipping in od
im not a expert OR a novice on trannys, so please help.my firebird randomly goes from OD/4 when driving around 50mph. is it time to get a rebuild? its an automatic, and i think it has 5 gears ((im not sure)) im a newb to my car. lol.
Axle/Gears: '01 3.42 10 bolt
congrats on resurrecting a 3 year old thread....lol
that actually sounds pretty normal for a factory 700r4. it is "searching".
btw, your trans only has 4 gear ranges and then lock-up for the torque converter so it can feel like it might have 5 gears but it actually doesn't.
Engine: v6 3.1L
Axle/Gears: ???
so im ok. good. lol thought something was wrong. i used the
and didnt look at the date, but i thought it would fit my problem/concern.
thanks
and didnt look at the date, but i thought it would fit my problem/concern.thanks
Hawk312
Aug 22, 2017 08:55 PM
maroe624
Apr 16, 2017 08:29 AM
someone972
Aug 30, 2015 12:52 AM
