How much stall for my combo?
Old Dec 10, 2004 | 06:38 PM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Hi everyone,
I need help deciding on a stall converter for my truck. I use it for 99% daily driving and the other 1% is towing.
It's a GMC C1500 full size truck. Weighs in at about 5000lbs. Has a SB 350, trick flow heads, pocked ported, valves de-shrouded, comp magnum 280 cam, 230/230 @0.050, 280 adv, .480" lift. Headers, dual exhaust, and ported and polished TPI. Should make close to 375 ponies.
Behind it is a TH350 Lock-up transmission with a 10 bolt 2.73 diff.
In the next few weeks I'm going to pull that 10 bolt and install a freshly re-built 12-bolt 3.42 diff and wanted to get a good stall converter to match.
I was thinking 2500 lock-up?
Should I go higher?
Thanks,
HowdyDuty
Old Dec 10, 2004 | 07:28 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
Re: How much stall for my combo?
Originally posted by HowdyDuty
Hi everyone,
Should I go higher?
Thanks,
HowdyDuty
Im a fan of the 2800 stall. Good street stall. Go Vigilanti what ever you do. Probly spelled that wrong!
Old Dec 10, 2004 | 07:48 PM
ljnowell's Avatar
I have an engine with that exact same cam right now. 3000 no less, trust me.
Old Dec 10, 2004 | 10:35 PM
supermouse68's Avatar
Car: 1988 firebird
Engine: 462 bbc
how much compression are you running and is it a stock intake?
Old Dec 11, 2004 | 01:22 AM
HowdyDuty's Avatar
Car: '84 Chevy 1500
Transmission: TH350
Comrpession is around 9:1 and it's a stock intake, but has been ported and polished.
-HD
Old Dec 11, 2004 | 02:48 PM
Car: 1988 firebird
Engine: 462 bbc
a lose 2500-2800 wouldwork fine i hade a .060 over 350 with 236 dur @ .050 490 lift in a truck and ran a boss hog 2800 worked fine with a 3.42 gear
Old Dec 11, 2004 | 07:04 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
call the manufacturer and tell them what you have and answer any questions they may have of you...they can tell you exactly what you need.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
