4L60E with PCM and carbed engine?
Old Dec 13, 2004 | 10:20 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I was wondering if anybody has done a 4L60E (electronic) transmission swap into a car with a carburetor.
I was considering getting a 4L60E tranny, LT1 PCM and harness, and then install the necessary sensors for the PCM to control the tranny (MAP sensor, TPS sensor, VSS sensor, maybe coolant sensor).
Currently I have a carbed ZZ4 engine with a 700R4 that shifts like crap; I want to replace it with a tranny that can be programmed to shift anywhere I want, instead of ***ing with that TV cable.
If this works I think the biggest challenges would be rigging up the TPS sensor to the carb and tuning the tranny. The car is a 92 so it originally had EFI and has a lot of the old sensors already... just a matter of running the wires.
Anyway just wondering if anybody has attempted this and what your successes and failures were.
Thanks.
Old Dec 14, 2004 | 10:27 PM
blkgta's Avatar
trans
canyou just get the tci controller for the trans ?
Old Dec 15, 2004 | 10:22 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yeah, that's the way to go. The programmer will allow you to program the trans with a laptp to do whatever you want. You can adjust line pressure, shift points, shift firmness, ect. I think they make them for the 4L60E. I know they are available for the 4L80E. The 4L80E also has the option of using a stand alone PCM from a Diesel truck that's been reprogrammed. They never put a Diesel in front of a 4L60E though. It would be like pulling the pin on a handgrenade and wrapping the lever with a rubber band. Eventually that rubber band is going to fail and the grenade is going to explode!
Old Dec 15, 2004 | 10:37 AM
blkgta's Avatar
controller
thats what i have on my car
same controller for 4l60 & 4l80
my car is fuel injected
but the carb shouldn't matter
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
