POSI help
Old Dec 15, 2004 | 08:13 PM
1984HO's Avatar
Car: 1984 Z28
Engine: LQ9 W/ Howards ASA cam+Fast 90
Transmission: T56 Mgw shifter
Axle/Gears: Currie 9inch w 4.30 gears
POSI help
any one know where i can get a single or set of the pretension spring plates( the ones that go on either side of the springs and push out on the cone clutch assemblies) for my auburn limited slip unit?? gm stopped making them so im out of luck there .....anyone have one or know where to get there
Old Dec 16, 2004 | 05:45 PM
brutalform's Avatar
Correct me if Im wrong, but I believe that the Auburns are un rebuildable.
Old Dec 16, 2004 | 06:01 PM
1984HO's Avatar
Car: 1984 Z28
well i followed the instructions on there website, more of a freshening thatn rebuilding just sand cone clutch surface and seat with 250-300 grit sand paper and check plates and spring, and then as i went to put it back together, on eof the plates cracked i had seen the crack cut hought it was a parting line or manufactureing defect, i called DTS today and they have the kit in stock so im all set
Old Dec 16, 2004 | 06:26 PM
brutalform's Avatar
good deal!
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
