Facing a decision need help?
Old Dec 19, 2004 | 06:20 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
My world class T5 is starting to act up. I have 3 options that i can thank of since i want to stay manual. One is rebuild the T5 and put stronger guts in it. Two buy a good tremec. Three do a T56 swap. Right now i have whats in my sig performance wise but with in the next few months i will have a 177 blower and a set of AFR's. I am looking for which one u thank will hold up and the best bang for my in the long run. Any opinons?
Old Dec 19, 2004 | 08:09 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
The t56 is nice, but the Tremec will do the job and it is probably less expensive. If you want a 6speed then the t56 is the way to go. If you want to get real frisky in the HP department check on a Doug Nash (now Richmond) 5 speed. You may find it comparable in price once you buy all of the pieces.
http://www.superchevy-web.com/search...ssion&x=9&y=10
you may find this useful
Old Dec 19, 2004 | 04:57 PM
brutalform's Avatar
The Tremec TKO is one strong piece of equipment. If you want to keep it a stick, this is the way to go. It will bolt right in a third gen with no problem. Im not sure if a T-56 is an easy bolt in though.
Old Dec 19, 2004 | 05:01 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I agree with brutal form. The tremec is a tough trans and they shift like butter!
Old Dec 19, 2004 | 06:06 PM
Car: 83 Z28
More tech stuff for you:
http://chevyhiperformance.com/search...+swap&x=12&y=6
IMO the T56 swap looks like a PITA
ZZ3Astro
Aug 13, 2019 12:57 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
