i just wanna know.
Car: i drive a 82 and 92 camaro.my 82 is a 305 3 speed auto "sport coupe"(RS technecly) and my 92 is a 25th anni. RS 305 5 speed
Engine: both my girls have 305's
Transmission: my 82 is a 3 speed auto and my 92 is a 5speed manual
i just wanna know.
i was wondering what rear end i have in my 92 rs 305 5 speed camaro. any thing will help(ratio,posi,???)
Car: 4
Engine: 6
Transmission: 5
Probably a 10-bolt with 3.08 gears, not posi.
Keep doing what's in that excessively large pic, and you won't have to worry about what it is for very much longer..... because it will be dumpster stuffing.
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
the RS did not come with a posi, you have a 10 bolt with a 7.65" ring gear, 28 spline axels, and either a 3.08 gearing which I believe a lot of the manuals got, or a 2.73 which was common with most automatics and some manuals
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Though hard to see, that isn't even a RS... not even late 80's Looks more like a 83 Berlinetta to me???
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What was said above it correct. A posi could be ordered for the 3.08 T5 TBI car but for the cost of it you could step up to a TPI car. There were a few out there though. Chances are you have the one wheel peel as again mentioned above. Unless you are the origonal owner your rear could contain anything. The only way to be 100% sure is to take off the cover and do a little math. A little wrench time will tell all.
Car: '91 RS, F41
Transmission: WC T5
well, if there was just 1 mark on the road after that pic, then you got the good old peg leg rear.. if there was two marks (which i doubt) then you got a posi.. doesnt look like your cars was sliding to the side during that burnout, so you more than likely got a peg legger...
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
jack up the rear mark the tire and drive shaft, count the number of times the tire turns to drive shaft that is your rear end ratio but most likely non posi also look up your rpo codes
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
This brings a good question for once. I just bought an 84 Z28. It was owned by an old woman that pretty much babied it. It is stock from what I saw, but I never removed the differential cover, nor did I even fhantom the thought of doing a burnout
. What stock gears came in that car for that year? Also, did it have a posi?
. What stock gears came in that car for that year? Also, did it have a posi? Junior Member
Car: 1984 Z-28
Take in consideration that I bought this car two weeks before I deployed and I have already unsuccessfully had my tranny rebuilt,
, had to do a complete engine tune, install a dual battery setup, and find out the tranny will not turn in any shifted position.
Great to be me ain't it?
your right that is a early third gen Cruzin Kaz cause if you read my profile you would notice i have a "82" as well as a 92. the one in the pic is the 82 and is a sport coupe. my 92 is an actual RS and it is also a 25th anni. i do know what i have!
THE PIC IS OF MY 82 SPORT COUPE!!!!!!!!!!!
NOT MY 92 25TH ANNI RS!!!!!!!!!!!
Car: 92 Camaro RS
Engine: 305 TBI
Then why was that pic posted ??? It does nothing to help with the question being ask. And if the car is stock and came with the 5-speed it should have 3.08 gears and is the open type, NOT POSI
Engine: T.P.I L98.
Transmission: TH350
hey sorry no biggie i just wanted everyone to know what one that was.
its all good
its all good
Pac J
May 17, 2020 10:44 AM
MadOTC
Oct 13, 2015 04:46 PM
