Hanging trans off an engine stand?
Old Dec 30, 2004 | 10:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hey, just a quick question:
Its ok to hang a trans off an engine stand, right? I mean, bolt the bellhousing to the trans, and then bolt the bellhousing to the engine stand, the same way it would bolt to the block. Is it ok to do this, since there is no support under the tail end of the trans?
I just recently got a ST10 for my Camaro, and I'd Like to put it up on my engine stand so I can check it over and clean it up a bit. IMO, it would just make it easier.
Old Dec 31, 2004 | 12:20 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its holding the rear of the engine up when its in the car so I would imagine that the case should be strong enough to support the transmissions own weight.
Old Dec 31, 2004 | 06:54 AM
ede's Avatar
ede
don't know if it's alright or not but i've done it once, maybe more
Old Dec 31, 2004 | 10:28 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Yeah, but let's not forget there is usually a trans x-member supporting the trans when it's installed so it's not hanging from the bellhousing normally.
But that's not saying it won't work on an engine stand either...
Old Dec 31, 2004 | 03:20 PM
Air_Adam's Avatar
Thats exactly what I was worried about.
Old Dec 31, 2004 | 04:14 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Itll be fine. Actually, the 55-57 Chevys didnt even have a trans crossmember. I know that for a fact. Ive hung many by the bellhousing and even by the pan rail.
midge54
Sep 2, 2020 07:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
