Ten bolt blueprints, need specs
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Any body got a drawing they can post with the outer specifications/dimentions of the housing/perches/brackets for the third gen f-body 10 bolt rear end?
I did a search and came up with nothing here or on the net.
Thanx ahead of time.
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I have an 8.5 10 bolt off a 96 Impala SS with disc brakes and a posi. I don't know the gear ratio yet, it is a 4:56 or lower gear (its on a dirt track Monte SS and its been rebuilt and the gear changed) so I will have to install a 3:73, no biggie.
I want to narrow it to fit under my 87 T/A, and when I do it, I want the exact location of all the brackets and the width of the rear with the proper pinion location so I get it right the first time.
I'd use a 9" but the 8.5 was free, and all I got to put into it is a gear, custom axles, and re-drill the rotors to fit the new axles with the smaller bolt pattern if required (we have a bridgeport at work and I will try to drill them myself first).
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Originally posted by ede
i'd build a jig around the 3rd gen rear and use that to swap brackets over
I agree the prints are not needed, but I just wanted to have them for reference.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
10, 1996, 85, blue, blueprint, blueprints, bolt, bolts, cheytac, differential, disc, impala, intervention, prints, rear
