T-5 Speedo Gears and Sleeve, Problem?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I sent a speedo head into a GM service center for repair/calibration. I've cleaned and lubed the speedo cable housing and cable itself twice, but I still having a bouncing needle of some 5 mph at 75, which on a 145 speedo seems a lot. Do I simply need to replace the speedo cable or could the speedo gears (drive, driven) and/or sleeve be the problem? I'm fishing for anwsers.
JamesC
JamesC
Car: `86 SS / `87 SS
Hey James. I had somewhat similar problems on my 87 SS (120mph speedo; speedo guts are similar but different)
I had all new GM speedo gears / sleeve & speedo cable. Well I have repaired speedometers before so I pulled the speedo and upon disassembly, I found the trip odometer cluster to be faulty and locking up. It would do a click thing every so often, or it would work fine, or it would do as you described. I installed a new trip odometer cluster as the rest of the speedo checked out fine and my speedo has worked great ever since.
-Matthew
-Matthew
The GM service center took care of the trip as well when I sent the speedo head in, so that shouldn't be the problem. The followin link is my fix to that particular GM screw-up. By the way, thanks for the sleeve and gear. I picked up a new OEM speedo cable today, but since the high here in Kansas was mid-twenties or so, I'll probably not attempt any repairs for a few months.
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
JamesC
Gotcha. Yeah mine don't have that j-clip (or related problem) the trip odo cluster was just randomly siezing up. Cable is a good possibility then.
By the way, when I replace the sleeve, will I get a flood or dribble?
JamesC
JamesC
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
JamesC
JamesC
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
