VSS Question!
Old Jan 7, 2005 | 12:29 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
VSS Question!
Hi there
I just did a swap on a 91 Z28. I changed the rear end from a 2.73 10bolt with drums to a 3.27 9 bolt with discs. I was wondering how I would go about fixing the speedo difference, do I just change the VSS OR is there a box between the VSS and the speedo itself that calibrates the gear ratio? Any help would be great! thanks!
its electronically driven and the one from the 89 GTA I took the rear end from doesnt fit the 91
Old Jan 7, 2005 | 08:00 AM
TexasLT1's Avatar
Car: '92 RS
You have to change the speedo gears themselves to the right combination for those gears. Someone will chime in with the right ones, but you could probably do a search for them too as I know its been posted.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
