Can anyone locate checkballs in 88 700?
Old Jan 7, 2005 | 01:43 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
I did several searchs for the locations of the 7 1/4 inch and one 5/16 inch check ***** in my non shift kitted 700,but all the posts only discussed the shift kits. I think i have the seven smaller check ***** in the correct locations but cant seem to be able to locate the larger ball.
Old Jan 7, 2005 | 02:44 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: Can anyone locate checkballs in 88 700?
The 5/16 copper flashed check ball goes in the round pocket in the case just to the rear of the tv hole in the case. The hole where the cable comes thru. You will see round pocket within 3/4 from the tv holes edge. Although I have not done it, some builders recommend leaving this ball out.
Old Jan 7, 2005 | 09:03 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Axle/Gears: Moser 4.56
Maybe these will help?
Attached Thumbnails Can anyone locate checkballs in 88 700?-check-ball-1.jpg
Old Jan 7, 2005 | 09:04 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
I can only find 6 though.
Attached Thumbnails Can anyone locate checkballs in 88 700?-check-ball-2.jpg
Old Jan 7, 2005 | 09:05 PM
Eats5.0's's Avatar
Car: 84 Berlinetta
Engine: junk 350
Transmission: TH350
Good Luck.
Attached Thumbnails Can anyone locate checkballs in 88 700?-check-ball-3.jpg
Old Jan 8, 2005 | 09:30 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
The strange thing is the large checkball is chrome same as the other ones. I have an 86 service manual that says its copper also. Dont know if that means anything or not. I guess ill just throw it in the tv exhaust hole and hope for the best. Thanks guys.
Vintageracer
Sep 24, 2017 12:34 PM
6998poncho
Sep 25, 2015 02:56 PM
Nikole
Sep 24, 2015 08:12 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
tonys91rs
Sep 2, 2015 07:07 PM
