Performance Servos
Old Jan 9, 2005 | 08:54 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Performance Servos
What the hell are these things..? I know their transmission parts but what do they do and whats the benefit of replacing one with a performance one?
Old Jan 10, 2005 | 11:32 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The servos regulate the application of the band and clutches inside the transmisson. Servos with greater surface area provide greater holding power, and reduce the chance that the trans will slip. Several companies offer them, but the Corvette servos are some of the best to use, and can be had from your local GM dealer. I don't know the part number off hand, but I'm sure someone here does.
Old Jan 14, 2005 | 09:09 PM
chris718's Avatar
the gm corvette servo is very efficient.the bigger piston multiplies clamping force based on the very basics of hydraulic principles.example 200 psi apllied to 1 square "is 200psi clamping force .200 psi of clamping force applied to 3 square "is 600 psi clamping force .bigger servo equals more clamping force firmer shift less slip.
Old Jan 15, 2005 | 07:39 AM
chris718's Avatar
post didnt make it to the top because of flood protection
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Dragonsys
Sep 25, 2015 03:51 PM
