Anchor Transmission mounts
Old Jan 10, 2005 | 11:05 AM
bobdole369's Avatar
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
After realizing my tranny mount could be broken (thanks boards), I looked and sure enough its destroyed.
I bought the el-cheapo Anchor 2394 (maybe 2934) $7.99 Autozone special tranny mount.
I know, I know, get the poly. I will. I've never done a tranny mount before and I figured I'd break the cheap one first, I'll get the poly energy suspension part in a week.
This cheap Anchor part has a rubbery "peg" where it would appear from other posts, and pics, there should be a bolt with a nut on it.
Did I get the wrong part somehow?
1989 Firebird 2.8L auto
Old Jan 10, 2005 | 11:12 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
First, I'm not going to tell you you should have gotten the poly mount. The mount you broke lasted 16 years, and probably failed due to expose to the elements and the degradation of the rubber rather than due to the design. I've actually swapped vehicles to poly, and then swapped back to rubber because of vibrations and poor driveline angles.
A stock car needs stock parts. A poly mount really doesn't buy you anything for the additional money. In fact I know several racers who run poly or solid motor mounts and a stock trans mount.
The mount should have two studs, or two threaded holes for bolts (the stock mount uses studs, but a lot of repalcements just have tapped holes and you will need to source some bolts). Changing the trans mount is very easy. It'll take you longer to get the car up on jackstands than it will to change it.
Old Jan 10, 2005 | 12:54 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
The "peg" is probably just a rubber cap over the stud to protect the threads. See if it will pull off.
Old Jan 10, 2005 | 01:25 PM
Yeah, sometimes the rubber is just molded over the studs too on parts store mounts. I've had to clean the rubber off the threads on a wire wheel before. That's not uncommon.
Old Jan 10, 2005 | 10:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i just got one of these trans mounts for my 84 pickup and it was 7.99 one too, its holding up great, the old one broke a couple weeks ago when i was swapping in the 350 engine,
it lasted since 84 til recently, new one will hold up another 20+ years im sure
autozone didnt give me a nut to go on the stud though! bastards! i had to go find one, it was metric and a PITA to find one took forever digging through my hardware stashes to find one that fit right
had to torch off the original, the stud was busted loose in the mount rubber, it was old rotten worn out,
its normal
so dont worry about the new one,
go and run it
good luck
Old Jan 11, 2005 | 03:45 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
It is not Auto Zones fault for the mount to not come with a nut. So please don't call them harsh names. How often do replacement parts come with hardware anyway?, not very often.
Old Jan 11, 2005 | 06:10 PM
TheGreatJ's Avatar
That depends on what you get, and who manufactured it. Most Delco ignition modules come with new bolts. The cheap reman water pump I put on an '82 Regal at work today came with new studs for the pulley/fan. The better brake pads (i.e. Wagner thermo-quiet) come with new anti-rattle clips. A lot of the thermostats for newer vehicles come with the O-ring already on the 'stat.
Energy Suspension tranny mounts come with hardware, last time I checked.
And in a sense it is AutoZone's fault....for carrying the cheapest parts they can find.
Old Jan 12, 2005 | 02:45 PM
All new parts should come with all new hardware, and it should be stainless steel. Wouldn't that be great? I'd pay just a bit more for that.
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
theshackle
Aug 23, 2015 03:49 PM
