Some simple rear end ?s
Old Jan 12, 2005 | 10:27 PM
Super_GTA's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 357 Tuned Port Injection
Transmission: Borg Warner T-5
Axle/Gears: BW 3.45 9-Bolt
I've just got a few simple questions about my rearend if you don't mind. These may be stupid questions, but please... I would like to know. First question. I have a 9 bolt rearend that will only burn both tires when wet. If it's dry I can turn both off the line for a second, then one tire. I plan on pulling the cover tomorrow and changing the fluid to royal purple synthetic with trans-x posi additive. I bought the car over two years ago, and just recently got it running. I don't know when, if ever the fluid has been changed. Will the new fluid and additive fix my problem? Now for the second question. This is the stupid one. If my rearend was run without fluid, what kinds of problems would that cause, and what kind of damage? Thanks for your help!
Old Jan 13, 2005 | 04:55 AM
ede's Avatar
ede
no oil would trash the bearings, axles, and gears at the very least. why would you want to consider not using oil?
Old Jan 13, 2005 | 12:49 PM
Super_GTA's Avatar
I wasn't considering not using oil. I was curious what would happen if the oil had drained out after sitting for two years. I'm pretty sure it has oil, because I've driven it for a good 2,000 miles without blowing anything up or seizing anything.
Old Jan 13, 2005 | 02:59 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The problem is most likely the cones in the unit are damaged. There's a great new tech article on this right here on TGO. I'd order up soem new cones while they are still available. The 9-bolt is a fairly stout rear, and worth keeping as long as you don't have crazy plans for the car.
Old Jan 13, 2005 | 10:25 PM
88fbird's Avatar
Car: 84 S-10:(
I had a similar problem. The additive and oil change didn't help. If you go on 9-bolt.com they have a posi check you can use to check your posi unit out with. Just jack up one side and put a tq wrench on one of the lugnuts. If it takes more than 35'lbs to turn the wheel then the posi is good. I don't know if it is correct, but that is what is there. What ever you do, keep good oil in that rear. Especially if you have 3.45 gears. I stripped out my ring and pinion a couple months ago. It is nearly impossible to find a set of 3.45s. So, take care of them.
FBird
Old Jan 13, 2005 | 11:55 PM
Super_GTA's Avatar
Thanks for the replies guys. I'll try the torque wrench tomorrow morning and see what happens. So if it takes more than 35 lb-ft to turn the wheel then the posi is good, and all I need to do is change the fluid and add the posi additive. Sounds good. I'll see what happens. Thanks.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
